Old 12-07-2008, 06:44 PM
AZCACTUS's Avatar
AZCACTUS AZCACTUS is offline
Default Door Window Weatherstripping
I am currently installing all new weatherstripping on my 8/73 FJ-40. I finnished the door-jams and moved on to the wing-window and the window stipping. I may have jumped the gun on installing the door-jams first. I cant figure how to get to the roll-up window weatherstip that clips in at the bottom of the window frame that cleans dirt off as you roll the window down. Do I remove the window frame? Do I need to remove my new door jam stripping to do this? I am spending my summers in Gunnison/Taylor Park starting next summer and preparing for cooler weather. Any help will be appreciated. Jeff West
Old 12-07-2008, 07:42 PM
once you pull the window, you can catch them with a hook to pull the old ones out. the squeeze in allowing them to fit through the holes. then just press them back in.
Old 12-08-2008, 08:38 AM
AZCACTUS's Avatar
Default door window weatherstrip
Thank for replying! That answers one question. My biggest confusion right now is what do you have to do to be able to pull the window out. Does the window frame separate from the door itself? Aso this is a 73' FJ-40 that has a bug-wing window. The reason I need to know is because I am installing a door weatherstip kit from SOR that includes all window felt and window weather strip also. The bottom of the window frame has a metal strip running horizontal with clips that hold the strip to the frame so that when you roll the window down, dirt is cleaned off the window. Aso at the bottom of the window frame is a rubber piece that goes on the outside of the bottom of the window frame. I cant install either of these parts with the window in. I am assuming that the window frame comes off some how. I dont want to remove the wrong bolts on the inside of the door. Thanks again for responding NuclearMelon. When I get to Taylor Park in May ( weather permitting) I plan on coming to a meeting in Denver and hopefully be able to join this fine club. Jeff West
Old 12-08-2008, 08:53 AM
Originally Posted by AZCACTUS View Post
...NuclearMelon....
Old 12-08-2008, 08:58 AM
AZCACTUS's Avatar
Default Sorry
Did I say Melon instead of Lemon? Both are fruit and have the same letters in them. l must be diklexik
Old 12-08-2008, 09:07 AM
If the fruit fits!
Old 12-08-2008, 07:46 PM
AZCACTUS's Avatar
Default bump
bump
Old 12-08-2008, 07:55 PM
remove the interior of the door. There are 2 10mm bolts holding the glass in place at the bottom. You may have to crank the window partway up to reach them. Lift the glass out the top or lower it down to pop out the chrome/felt parts. At least on a '78. Not entirely sure about the older stuff.
Melon.... that's funny stuff.
Old 12-08-2008, 08:14 PM
AZCACTUS's Avatar
Default Door window
Thanks Farnhamstj! I'll try that in the morning!
