Old 12-08-2008, 11:33 AM
Default Place to buy drill bits?
Where do you go to buy good drill bits?
Old 12-08-2008, 11:44 AM
MSC. http://www1.mscdirect.com/CGI/NNSRHM tons of choices from Chinese to carbide, depending on how much you want to spend. whacha drillin?
Old 12-08-2008, 12:59 PM
Grainger - www.grainger.com - or visit your local store. They seem to sell more large bits with flatted shanks than Home Depot does. Prices are competitive and service is great.
Old 12-08-2008, 01:26 PM
Nick F.'s Avatar
Nick F. Nick F. is offline
msc, western tool, or enco. western or enco tend to be cheaper.
Nick F.
__________
|__|_[_____]_
|_[_L__ (o==o) _
()_)O()_)O=)_)
Old 12-08-2008, 01:30 PM
Cost Right Tools
Old 12-08-2008, 01:41 PM
Corbet Corbet is online now
I got a decent Cornwell set off Ebay a few years back for cheap. Us folk in poe dunk mountain towns have to use the web.
Old 12-09-2008, 09:08 AM
Slight hijack but still on topic...
15 of the 6mm x 1.0 bolts came out of my cap just fine. The heads on the other 6 snapped heads. Where (locally) did you guys pick up your left hand drill bits?
Old 12-09-2008, 09:42 AM
PB Blaster is your friend.
Old 12-09-2008, 10:38 AM
It was for most of them.
Old 12-13-2008, 09:40 PM
L43dean L43dean is offline
Default ricardojm broken bolts
centerpunch the broken bolt (still in the tub) ,dab with oil ,carefully drill out with drill small enough to fit in your 6mm un-damaged threaded hole , then chase the threads with your 6 x 1 tap and more oil. i suggest you buy the tap and die together . the die can chase and clean up rusty bolts for re-use . i like cobolt bits when available in the size you need . drill slowly in hardened steel bolts to avoid over-heating your bit and to keep centered .
