Old 12-11-2008, 03:20 PM
PabloCruise's Avatar
Default Chain Clamp Tool w/ Breaker Bar?
Does anyone have one I can borrow?
I need to replace timing belt on my Honda and need this tool to remove crank pulley... The little sucker spins counterclockwise! No "bump the starter" trick for me.
I would love to get this done this weekend.
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 12-12-2008, 07:34 AM
Or does anyone have a 50mm crank tool for the B18 engine?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 12-12-2008, 08:57 AM
i've always been able to get them off with an air wrench, wither that or leave it in gear and get a helper to mash on the brakes while you give it a good yank.
Old 12-12-2008, 01:31 PM
I like the brake idea!
I was wondering why the manual didn't say impact wrench... They did say not to spin it CW as it is an interference engine. I guess you could skip a tooth not having belt tensioned going CW?
Have you successfully impacted them off?
THanks!
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 12-13-2008, 02:11 AM
Myredyota's Avatar
Myredyota Myredyota is offline
I have one of the "chain clamp tools" but I have never used it on our Hondas! I have always used a pry bar against the flywheel. I did use the brake trick when I did my 3.0 in my truck years ago. If you still need to borrow my chain wrench, let me know. Don't forget to do the water pump at the same time.
Carey--Arvada
2017 Tacoma SR5 (mall crawler)
Old 12-14-2008, 09:56 PM
Thanks for all the ideas - I lucked out!!!
I was ready to tear into the timing belt and go after the tensioner or the water pump. On my way in I verified each belt driven accessory. It turned out to be the idler pulley that tensions the AC belt!!!
$50 pulley - will be here Tuesday!!! I bet I could source the bearing itself for less, but it is going to be a busy week at work...
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
