Old 12-18-2008, 03:34 PM
Sorry I was not more timely...
No worries. Thanks for the suggestion though.
More questions. Is there any benefit to bench bleeding these before I begin, or can I just bolt them on and bleed them via the pedal? Is the clutch free play set prior to bleeding?
(I need a manual for this rig)
Old 12-18-2008, 03:45 PM
Go to this thread.
http://www.risingsun4x4club.org/forum2/showthread.php?t=3099
If you follow the directions in that thread, you will find a folder called 1993_Truck_FSM. This is the whole FSM in PDF. It will give you enough understanding on this, it's the same for all trucks in principle.
Old 12-18-2008, 04:06 PM
Go to this thread.
Got it, Thanks!
Old 12-18-2008, 04:32 PM
isotel's Avatar
isotel isotel is offline
When i picked up my 89 4runner, the PO handed me a bottle of Brake Fluid, and showed me where he fills it up every week.. (Clutch Master)
My Driver side Carpet is BLACK due to the leaking Master for 5 years or so.. Under the Carpet there is alot of Surfuce Rust..
Took me 20 minutes and $5 at the Junk yard to pull out a new one. but now i need to put in a new carpet kit!
1976 FJ40 TBI350 700R4 Dana300
Colorado Land Cruisers
CrAwLoRadO.com
Old 12-19-2008, 09:17 AM
Go to this thread.
I find I don't need to bench bleed with a pressure bleeder. Saves a lot of unnecessary under-truck verbage... LOL. ESPECIALLY with the clutch system, as it goes up before it goes down...
KDěRCH
Old 12-19-2008, 09:28 AM
I have a Motive power bleeder, too. It's OK on the brake M/C, a major PITA on the clutch master (I have my ARB compressor in the way, which makes getting in there extra un-fun). I'd personally bench bleed the clutch M/C rather than fiddle with the bleeder. I only have the universal adapter, if there exists a proper adapter then Power Bleeder might be much easier to deal with. I routinely end up blowing fluid out of the stupid thing at first.
Old 12-19-2008, 09:58 AM
Before you add fluid to the reservoir... pressurize it and make sure it holds pressure. Adjust till it does. Then add fluid.
DAMHIK...
KDěRCH
Old 12-19-2008, 10:02 AM
I read also that you can "gravity bleed" the clutch master. I don't have a pressure bleeder, so I was going to try this gravity method, then finish the old fashioned way. Thanks for the tips everyone, I'll let you know how it goes, should be finished this morning.
Old 12-19-2008, 10:03 AM
Luckily I'm catching mine early. Only a few drops have managed to hit my carpeting.
Old 12-19-2008, 12:26 PM
I bench bleed mine first having wasted time with air in the master cylinder on a couple of racecars in the past. It only takes a couple of pushes.
Then, I put a 2x4 between the pedal and the seat to depress the pedal. I opened the bleeder on the slave and worked on something else for a spell.
I kept an eye the clutch master level. It gravity bled just fine on my truck.
KD0FDS
Stephen
