Old 01-05-2009, 02:29 PM
Default R&p
Well, I did it. I need to gear the DD to 4.88s and already have a front IFS diff laying in a bin in my garage. Tired of slipping the clutch and finding 5th superfluous.
So shopping Randy's R&P, I saw they had a decent price on gears. Oops, those aren't recommended for 'quiet' trucks... . Ah, there are the quality ones, they are.... HOLY $MOKE$.
Marlin is better pricing. About ready to drop the hammer, and out of curiosity I visited Trail-Gear. I am not fond of the shenanigans Chris has pulled in the past (IMHO, YMMV, etc) but that was then. Geez... $100 less. That is starting to matter. A lot.
I was quite suspicious of the quality, but Google revealed no bad experiences, only good ones. Huh.
So I pulled the trigger. I guess I will walk the skinny plank/long branch/insert metaphor for lonely risk here.
"Hold my beer and watch this."
KDRCH
Old 01-05-2009, 02:42 PM
did you have 5.29 in there before? Or?
Old 01-05-2009, 02:43 PM
Stock 4.11s pulling 33s with a rebuilt 22RE.
Just for clarity, TG was not $100 less than Marlin, nearly $100 less than Randy's.
KDRCH
Old 01-05-2009, 02:48 PM
Yep, that's me, honorless.
From what I read, TG has been behaving rather well lately and doing a good job. so...
KDRCH
Old 01-05-2009, 03:56 PM
I'm still rocking the 3.73's with the 35's in my truck which I DD. Sucks more for the wheeling than the daily driving actually.
that's no fun.
Bill, Trail Gear? Disappointed. Have you no dignity, no honor? For all that talk of supporting the guys who got our six. :-)
No, he still had 4.10 stock gears with 33" tires = yikes!
BTW, yes, I'm on Marlin's Christmas card list...
Old 01-05-2009, 04:20 PM
Truly despicable! I have hung my head in shame for several months after patronizing TrailMarts 6 stud knuckles and forged arms. At least I can justify in a way that neither Marlin or Bundrant sell the 6 shooters and Gieger is the only source. I believe Chris "the Reaper" sells Nitro gears as his bargain basement line which seem to be working out. BTW Your local vendor Mr. Slee also sells Nitro gears, JFYI.
Old 01-05-2009, 07:05 PM
Chalk this up to mini truck uniqueness, 4.10 gears + 33" tires + 22R-E = frustration on a daily basis. Your 5th gear is along for the ride unless you are coasting down Floyd Hill and clutches must be considered annual maintenance items. OTOH, 4.10 gears are preferred for harder trail work with dual cases or even a single 4.70 case, the deeper gear sets tend to fail sooner and with drive train reduction you don't need low gears in the axles. But for a 22R truck driven on a daily basis, matching gearing to tires is a little more than luxury.
true, I was poking fun more than anything
Old 01-06-2009, 10:23 AM
OTOH, 4.10 gears are preferred for harder trail work with dual cases or even a single 4.70 case, the deeper gear sets tend to fail sooner ...
So goes conventional wisdom. But...
Zuk disagrees (though it does make intuitive sense that less tooth surface engaged = weaker). Zuk swears proper setup, especially carrier bearing preload, makes 5.71s stone reliable:
http://www.gearinstalls.com/410suck.htm
He has done a ton of setups for radical vehicles.
Carrier Bearing Preload a la Zuk
I do know there was a rash of Toyota factory elockers that blew up ring gears for no obvious reason, and it makes sense that carrier bearing preload may have allowed overmuch flex when locked. Dunno. Not yet been brave enough to do 100 ft./lbs of tightening. Mebbe I will this go round.
KDRCH
Old 01-06-2009, 10:27 AM
First I've heard of Nitro being TG's TCs, somebody said they were Yukons (made in the same factory as Yukons... which doesn't quite make sense since Yukons are repackaged USGear, Precision, etc.). Where didja hear this?
Oops.
...6 shooters and Gieger is the only source.
Give Sky Mfg. about three months and see if that is still true... That would be ironic...
KDRCH
Old 01-06-2009, 01:30 PM
It appears I must have fallen into a rumor mill as I have scoured and cannot find anything to back up my claim. Must be another reversed engineered knock off that TrailMart is famous for I'm guessing. Then again it possibly could be the same manufacturer that Randy's (Yukon) and Reider (Precision) use....I haven't a clue.
