Old 01-05-2009, 06:56 PM
Default what's leaking?
So when I was in Moab this spring for 10 days of 4-wheeling (), including Cruise Moab, I developed a leak that would drip-drip-drip while out on the trails. Can't remember for sure, but I think it was near the clutch inspection cover.
Now that I'm home and the truck isn't rolling and bouncing for hours on end it doesn't leak a drop.
Does that sound like a rear main?
Old 01-05-2009, 08:35 PM
I doubt its the rear main seal. I would expect it to be rather insensative to bouncing or vehicle angle. OTOH the valve cover or side cover may have a poor seal that is only noticeable when the truck spends some time tilted at a 30 deg angle.
Old 01-05-2009, 09:20 PM
Are you running heavier oil now? Since I started running Rotella, I don't leak a drop.
Old 01-06-2009, 08:38 PM
ttubb's Avatar
ttubb ttubb is offline
Default Rotella
Are you running the 15/40 dino or 5/40 syn? TT
KA7TLT - TLCA 13015
Old 01-07-2009, 02:43 PM
treerootCO's Avatar
Front input seal to the transmission will leak at extreme angles.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 01-18-2009, 10:04 AM
I'm running 10W-40 dino oil (no sense to me to run synthetic in this machine), it seems to be fine until I have a couple days in a row of the engine running for significant periods of time (like several hours), combined with a lot of bouncing, up and down angles, etc.
Someday I'm going to have to tear it down to replace the clutch/rear main/tranny output/and maybe a surprise transfer case upgrade, so I guess I'll just monitor it and see what happens.
