Notices
Old 01-21-2009, 02:50 PM
Default Bolts
What's the practical difference between a flange bolt and a regular hex head cap bolt? Other than the obvious (flange bolt has the integrated washer), is there a specific application that makes one better than the other?
Flange Bolt:
Hex head bolt:
Old 01-21-2009, 02:59 PM
the flange is often stronger than a washer and won't deform in hi torque situations.
Old 01-21-2009, 03:05 PM
Manufacturers like flanged bolts because they take less time to use, the washer can't fall off the bolt.
Old 01-21-2009, 03:09 PM
Makes sense. Can you/should you use a split washer with a flange bolt?
Old 01-21-2009, 05:04 PM
Depends on if you want the bolt to stay in place or not. ;-) You can, although I think they are typically used with lock nuts. But if you look at the photo of the bolts you linked they can also be toothed on the bottom which is supposed to grab into the metal as you tighten it down and lock it. I prefer the old fashioned way of a bolt + split washer + flat washer + nut and Toyota's bolts are nice because they have captive washers that don't come off.
Old 01-21-2009, 05:25 PM
I prefer them to stay on, but with some rust mitigation there's no longer a guarantee....
