Old 02-07-2009, 03:06 PM
If you are at 207K on your original gears as well, or close to it, you might consider pulling the diff and checking the carrier bearing preload too.
http://www.gearinstalls.com
The bearings in the diff are much younger, I'm pretty sure I had Robbie replace them when the gears and lockers were installed. Yeah, pretty sure.
Old 02-19-2009, 08:09 AM
J Kimmel J Kimmel is online now
thought I would toss out a quick update...
Had front range go through the driveshaft, like I thought when I pulled it, all was fine. The re-lubed and re-balanced it and that was it. While I had it out, I drained and re-filled the rear diff too. Nothing out of the ordinary was in the old fluid I drained either, not under filled, etc.
So the re-filled diff and re-balanced shaft are back in, and the noise is gone, so it seems all is well for now
oh and the best part...the CE light has been on since I bought it a few weeks ago. I haven't gotten around to diagnosing yet, but I guess it got bored cause halfway home last night it turned itself off, and even driving to practice later on and then back home, no more CE light
Old 02-19-2009, 09:24 AM
Check your canister VSV. Common failure around that mileage. DAMHIK. Darn easy to fix though. Pull the code.
KDěRCH
