Old 02-22-2009, 09:10 PM
PabloCruise's Avatar
Default 3FE Troubleshooting
So I have this 3FE in a Pig and have been tracking down little issues.
The most concerning one is an intermittent idle problem. Sometimes when warm, I will lose the ability to idle.
I am swapping out radiators this weekend and thought I would pull the throttle body and ISC to check them for function and spec.
Also checked air flow meter - it checks good against specs in the FSM
ISC checks good - both resistance and stepping.
Throttle body checks good, EXCEPT when clearance btwn lever and stop screw is supposed to be set to 1.09 mm or 0.0429".
I used two feeler gauges together to achieve thickness: .559 mm and .533 mm to achieve 1.092 mm. So it is a little fat, but that was the best I could come up with in the moment.
FSM says resistance at IDL and E2 is supposed to be infinite, I got zero
I may have been off a little, trying to arrange the throttle body and feeler gauges, and take a measurement at terminals...
Can anyone advise me if it is common for the throttle body to pass every other check, but fail here?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 02-23-2009, 09:47 PM
No Love?
Dang, I can't get boo out of the 60/62 forum on MUD w/ these questions.
Is the yahoo 3FE list my only place to field these mundane requests?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 02-23-2009, 10:02 PM
Crash's Avatar
Crash Crash is offline
[quote=PabloCruise;98242]No Love?
Is the yahoo 3FE list my only place to field these mundane requests?[/QUOT
Yes, TJ, the 3FE list is the only place in the world where you can get reliably mundane, but generally correct, info on the mighty 3FE fury of an engine.
It sounds as if your TPS is DOA and the only way to make it right is to replace it. Not that big of a deal really. They tend to get gunked up internally and not allow full travel of the internal mechanical parts which, in turn, sends erroneous electrical info to the not-very-smart 3FE computer (ECU). If you can't get it to match the FSM specs while you have it on the bench, replace the TPS. Be aware, however, that there are two throttle stops in the same tight area when the TPS is mounted to the throttle body and if you are trying to set the clearance specs on the dash pot stops, your TPS specs will be close but not correct and cause you some dismay.
Old 02-24-2009, 05:45 PM
Thanks Crash.
I am puzzled that the other positions check fine, just the one at 1.09 mm is opposite of spec.
In your experience, if I am off a little on that 1.09 mm gap, is that enough to give me a zero resistance vs. infinity?
Anyone have a TPS that passes they want to sell?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 02-24-2009, 06:11 PM
Crash,
Is the not-very-smart 3FE computer happy if the CEL has been removed?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 02-24-2009, 10:45 PM
Crash's Avatar
I detest electrical stuff. If the TPS doesn't spec out as it should on the bench, IMO, the best thing to do is buy a new one. Saving a few $$ on a used one is too risky, again, IMO. As for the ECU being affected by no CEL, I am not in the know. There are a couple of guys on the 3FE list that could help you though. It's very quiet there these days but Wayne Tangen is the acknowledged electrical guru and he usually checks in on the list every few days or so. Couldn't hurt to ask there.
When checking the TPS, if you see the correct resistance at the skinnier clearances and then resistance goes to zero at a wider opening rather than infinity, then I would say the TPS should be replaced.
Old 02-25-2009, 01:24 PM
Got it, thanks.
I'll field the CEL question to the list and hope that Wayne weighs in on the matter...
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 02-26-2009, 07:01 PM
What is odd is that I re-checked the TPS today and the two checks at WOT now fail. I swear on Sunday they were w/in spec, but now they go to 0...
I'm replacing.
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
