Old 03-05-2009, 11:56 PM
jacdaw's Avatar
jacdaw jacdaw is offline
Default Chrome
Chrome didn't work on Mac when I first tried to d/l it. Should I try again?
Sorry to continue the thread hijack.
Jon Newquist
TLCA 19964
Old 03-06-2009, 09:34 AM
If any of you guys have a set of the Staun or Smittybilt deflators that you want to sell, let me know.
Old 03-06-2009, 10:22 AM
got the link to work but its a little weird. loads a blank white page but if I scroll down the content is there.
May consider them but the are pretty costly compared to other options.
  #24
Old 03-06-2009, 12:12 PM
Originally Posted by Convert View Post
I had the Stauns for a while and they worked fine.But I switched to ARB's EZ-Tyre deflater it is much faster than the Stauns and is not a set psi. Picked it from Kurt at Cruiser Outfitters for around 37 bucks.
Dan describe how the ARB works, I'm gaining interest in this one
  #25
Old 03-06-2009, 12:21 PM
The EZ deflaters were created by Currie Enterprises. The very first ones were very expensive. When Currie outsourced them to off shore manufacturing it made them affordable and also opened up knock offs to the masses. The concept in ingenious and very simple. Screw the apparatus on the valve stem. Push the knob into the valve stem and remove it internally. Slide the large knob to open the open ports. Let the tire air down to where you want it then simply close the air ports, then screw the valve stem back into place that is out but still contained in the apparatus. Unscrew the assembly and move on.....no chance of lost valve cores.
Colorado Trail Patrol
Stay on the Trail!
  #26
Old 03-06-2009, 12:28 PM
snooped and found this great site......
Stay on the Trail!
  #27
Old 03-06-2009, 01:10 PM
Convert's Avatar
Convert Convert is offline
Looks like UB beat me to it. His explanation is spot on
Dan Reinmuth
47 Bantam Trailer/RTT
71 FJ40 project
TLCA 13269
KVRT
  #28
Old 03-06-2009, 02:05 PM
sounds like the winner. Thanks guys.
  #29
Old 03-06-2009, 09:12 PM
JadeRunner's Avatar
Cruise Moab Co-Chairman
I have been using the original Currie Ez Deflater, which I bought for 60.00 8 years ago with no issues. Not any faster than the staun guys at the trailhead but I control the psi the first time.
Scott Yoder KD0DHP
  #30
Old 03-20-2009, 03:03 PM
85Toy 85Toy is offline
You guys are a bad influence, and I haven't even met any of you yet!!! I have a set of Staun's, new in the plastic packaging, and I went out an ordered the Currie just now after reading this thread....guess I will do my own comparison.
'85 4Runner, LC Engineering 22RE, Locked F&R, 5.29s, 6" Spring Lift, TrXus MT's 34x12.5x15s, more...Busted Driveshaft - Cracked Block
'82 Supra w/ rare dealer-installed Spearco Turbo Kit and over $10K in upgrades! For Sale to fund repairs to 4Runner.
