Old 03-11-2009, 11:52 AM
Originally Posted by Crash View Post
I drive by the RapidScan trucks all the time and still get the notice that I have to go to the testing station. I think the guys in the trucks just sit there and drink coffee or whatever. I do make sure that I am either going a steady speed or decellerating when going by the trucks but no luck so far with any of our vehicles with bypassing a test at the station.
Uncle Ben, you'll get me to go to Bud's yet, won't you? Thanks for the cat tip as it may just be required.
I believe the test involves three screenings. If you decell everytime you might be jinxing yourself! I have also heard if they cannot verify your vehicle by clearly recording your license plate you will not qualify.
Correct! When you get your plate renewal notice it will state "No Emission Test Required" I have been exempt from test twice now and I hopefully will get the same news in a couple weeks when the post card should come.
Then it must be that my plates haven't been caught because the 4Runner (which is 100% stock) has had emissions test every time it's eligible. Probably Adolf Air Care just toying with me just to piss me off. If so, I can actually respect that.
Old 03-11-2009, 11:55 AM
"Adolf Air Care"......that could just keep me chuckling the rest of the day! Thanks!
  #24
Old 03-11-2009, 11:56 AM
PabloCruise's Avatar
Please keep us posted Crash, as I suspect EGR related malfunction is plaguing my 3FE...
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
  #25
Old 03-11-2009, 11:58 AM
Crash's Avatar
Crash Crash is offline
TJ, the EGR tests are very simple to perform. Do you have an FSM? If not I "think" I can scan the tests and email them to you.
  #26
Old 03-11-2009, 12:10 PM
Here's the one from the 22R-E and 3VZ-FE to give you some reference. It's not tough and probably similar on the 3FE.
  #27
Old 03-11-2009, 12:39 PM
Crash's Avatar
The 77exhaustq notes are very similar to the 3FE notes, just drop the 3,500 rpm test number to 2,500 for the 3FE.
  #28
Old 03-11-2009, 02:08 PM
Default Roadside testing
last month, for the FIRST TIME in my life, I have received a notice that I passed the roadside e-test and I didn't have to go to the station!
Sure it was in the MR-2 Spyder and not my truck, but it CAN work I guess.
I wasn't trying to pass the roadside e-test because my truck never passed even when I made a concerted effort to hit the roadside stations at the right time, right frequency, accelerating, blah blah blah.
It looks like you may need to be running REALLY clean to pass the roadside test. (The MR-2 Spyder is a ULEV rig)
KD0FDS
Stephen
  #29
Old 03-11-2009, 08:46 PM
X2 on what thefatkid wrote. EGR is all about NxOx. Stupid thing is, it is not an issue where we live due to our elevation. Higher combustion temps are what causes higher NxOx, and backing off on your timing may be the easiest way to pass, assuming your EGR is functioning as intended. I would look to these two areas before moving your registration.
  #30
Old 03-12-2009, 02:25 PM
Man, you guys are awesome!
Much Gratitude!!!
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
