Notices
Old 03-14-2009, 04:06 PM
rock_wagon's Avatar
rock_wagon rock_wagon is offline
Default Brake Line Hose Fitting Tricks?
I am in the process upgrading my brake line hoses on my 96 LX450 to a set of Slee hoses and I am having a really difficult time with one of the hoses.
Any one know any tricks for loosening up the fittings? I am struggling with the driver side from frame to axle, top connection. The 10mm wrench is just rounding the fitting. I have been hitting it with PB blaster but it is still not moving. Space is pretty limited around the fitting and I have been resisting using a pair of vice grips because I don't want to bugger up the fitting and have to replace the entire hardline.
Suggestions, tricks?
Thanks!
Will
2014 Tacoma
W0WIL
http://www.coloradobluemountain.com - Drink Local Wine!
Old 03-14-2009, 04:43 PM
sounds like it may be too late, but have you tried line wrenches? (flare wrenches, open end, but only a small section so they grab most of the sides unlike a regular open wrench)
Old 03-14-2009, 05:08 PM
jettaglxdriver's Avatar
jettaglxdriver jettaglxdriver is offline
Flair wrenches or a box wrench if you have the other end of the line off already. You could try a heat gun to loosen it up.
Thank you for calling. Press1" for English, press "2" to disconnect until you have learned to speak English
TLCA# 19853
1982 FJ60
1991 Toyota Paseo 38MPG baby
1995 JettaGLX VR6turbo project car
Old 03-14-2009, 05:11 PM
rock_wagon's Avatar
Actually I have never heard of one! It makes sense. It might not be to late yet, worst case I have a small file to clean up the nut. I will see if I can locate a line wrench.
Thanks!
Will
2014 Tacoma
W0WIL
Old 03-14-2009, 05:25 PM
Thanks!
Everyone should have flare nut wrenches in their tool box! Tubing nuts will flatten with a normal 2 or three side grab wrench because they are hollow!
Colorado Trail Patrol
Stay on the Trail!
Old 03-14-2009, 10:36 PM
Will,
I had a similar issue last year on one of my bleeders...Tried a standard wrench, crescent, and then a flare wrench with no dice - In the end it was a set of channel locks that finally broke the bastid free...Had to replace the bleeder.
One trick someone suggested at the time was to actually try to tighten it a tad and then loosen the bleeder. That may also have been part of what worked for me.
I know you aren't working on a bleeder but i would think the same process would apply here.
Get the flare wrenches (Harbor Freight sells them) and give it a go but if not, maybe gently working it with channel locks or vice grips. Lock 'em on there and try gently tapping with a small hammer?
Old 03-15-2009, 03:07 PM
rock_wagon's Avatar
Thanks for all the suggestions! I got a line wrench last night but alas it was too late the nut is fubared. Another lesson learned, get the right tool for the job!
Will
2014 Tacoma
W0WIL
Old 03-15-2009, 04:13 PM
Crash's Avatar
Crash Crash is offline
Will,
By all means, use flare nut wrenches on brake line fittings, they are the only way to go, but please, please, please buy at least Craftsman quality ones! Do it really right and buy a single 10mm Snap On if you can. The cheap flare nut wrenches will just flex and really round off the nut when you want the wrench to work in the tightest situations.
Old 03-16-2009, 01:28 AM
Agreed Steve but there is the rub...anyone been into a Sears lately? Is it just me, or do they always seem to be out of exactly what you need? Especially the more specialized tools. I've even asked them to order stuff in and they say sure, will do and it never shows up
Old 03-16-2009, 01:36 AM
Rising Sun Webmaster
You can save yourself the hassle and order S-K tools here:
http://www.mytoolstore.com/sk/catalog.html
This is probably more expensive:
http://www.skhandtool.com/Default.aspx
After all, S-K invented the round head ratchet wrench.
