Old 03-21-2009, 06:51 PM
PabloCruise's Avatar
Default 3FE - Codes 12 and 41
So I finally got my Check Engine Light wired into the Pig and now that I can check codes, I find it showing 12 and 41.
Code 12 is for the RPM Signal (Distributor)
-No NE or G signal to ECU w/in 2 seconds after engine has cranked
Code 41 is for the Throttle Position Sensor
-Open or short circuit in throttle position sensor signal
Wow, I thought my issue was lying with fuel pressure...
My underlying issue was that the idle would break down once the engine got nice and heat soaked. I did an ignition system tune-up and advanced the timing. PO had it set retarded, I got a lot more power out of it, but idle issue remained. I thought maybe the computer really wants dizzy set for 7* BTDC, otherwise it throws code 12. So I re-set timing dead-on the BB and took it for a drive, re-check codes - first check showed all good. I switched off the key and checked again; 12 and 41.
TPS tested bad when I had the throttle body off, so I replaced it with one from parts store. I installed using FSM procedure, and then tested using procedure in FSM. I could not get the resistance values that I should have.
I guess it never hurts to look at actual data!
I have access to a 11/88 FJ-62 for parts. As far as I know, I can purchase dizzy and TPS from this rig.
I imagine a 11/88 62 is technically a '89?
My 3FE is an early '88, based on block #.
Does anyone know if '89 dizzy and TPS will fit a '88 3FE?
TIA,
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 03-21-2009, 07:07 PM
PS: is it common for 3FE dizzy to go bad?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 03-22-2009, 12:27 AM
Only if it's in a Piggy!
Old 03-22-2009, 12:46 AM
That's not funny!
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 03-22-2009, 10:00 PM
The FSM lists resistance specs for terminals NE and G of 140 to 180 ohms
My NE reading was 300 ohms - so clearly out of spec, but not by much?
Has anyone rebuilt their dizzy to fix NE or G signals?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 03-22-2009, 11:35 PM
Chris's Avatar
Chris Chris is offline
TJ, my dizzy failed not long ago with no warning at all. ran to the store, all was well. Went out a bit later, nothing - code 12. The dizzy was dead. So, yes, it happens.
My research showed it's easier to replace than rebuild. $25 - $50 on 'mud.
Old 03-23-2009, 06:44 AM
Chris, did you check resistance values on your original?
Did the parts store warranty the one you bought from them?
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 03-23-2009, 09:09 AM
Chris's Avatar
I did and one of the checks came back with a zero reading, can't recall which so mine was obvious unlike yours appears to be. Rob (MaxsDad) gave me one he had so I just replaced it rather than rebuild or buy. Like I said you can pick one up on Mud for $25-$50 which is the way to go.
I have one that's my back up that you could borrow to see if that's your problem, you're welcome to pick it up if you're down this way. Since the last failure I decided it's good to carry a spare so it would just be a loaner though.
Old 03-24-2009, 11:01 PM
Thanks Chris, I am working on lining up a replacement.
Hopefully this and TPS will solve my issues.
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
Old 03-24-2009, 11:05 PM
Crash's Avatar
Crash Crash is offline
Webmaster
Oleg at Irbis Off Road probably has one if you want to find a used dizzy locally.
