Notices
Old 03-21-2009, 07:41 PM
bigbluefj's Avatar
Honorary Canuck Member
Default June 71 Tub
So i have a June 71 Tub and i was taking a look at it and on the transmission tunnel there's no hole for tranny or tcase would this be a three in the tree? if so where would the tcase hole be???
bigbluefj
Old 03-21-2009, 09:08 PM
theboomboom's Avatar
Yessir you are correct, a June '71 would be a 3 on the tree. T case shifter is mounted under the dash next to the e-brake. Our '71 is already converted to a 3 on the floor, someone else may chime up with measurements for ya.
Rick Maestas
KD0CGE
1997 T100 4x4
Old 03-23-2009, 05:00 PM
You will have to measure and cut the hump if you want to use it with a floor shifter and floor t-case shifter. I did this for the tranny shifter when I installed a 4-speed in my 71. I retained the under-dash lever for the t-case range selector and retained the vacuum actuated front drive, less clutter on the floor.
Old 03-23-2009, 09:23 PM
bigbluefj's Avatar
Well i'm going have to take a look at this tub now just to see what i have, i've never seen such a thing it was free so one can't complain i guess should not be to much trouble to put a hole??
bigbluefj
Old 03-23-2009, 09:54 PM
Just use whatever you normally cut sheet metal with. Zip wheel, sawzall, plasma torch, etc. Like everything, measure twice and cut once. You will have to clearance a couple of the bolt heads that stick up from the top of the 4 speed, it is taller than the 3 speed that the tranny hump was designed for.
Old 03-23-2009, 10:49 PM
bigbluefj's Avatar
well it will be awhile before i get to that part anyway so it's something to look forward to i guess..
bigbluefj
Old 03-24-2009, 12:37 PM
Jeff is right - and/or you can do a 1" body lift to allow the trans cover to clear the 4 speed. If you don't, the trans. cover will become an amplifier for transmission sounds and it will be quite loud. It varies from vehicle to vehicle, but my tunnel cover was never going to fit without a body lift.
Old 03-24-2009, 10:07 PM
Huh? What did you say?
Old 03-25-2009, 07:40 AM
bigbluefj's Avatar
Well e Chance of me having a stock transmission slim to none, but weird thing's can happen...
bigbluefj
Old 03-25-2009, 08:18 AM
I meant to say 'tunnel cover' - not 'trans cover' - Steve
