Old 03-22-2009, 07:46 PM
Default Type T-IV Transmission Fluid
I drained the '04 4Runner transmission and dropped 4 quarts of Mobil 1 ATF in it. I was looking through the manual trying to find the capacity to figure out how many drains/refills I'll need to do and to my horror, saw that the type of fluid that it takes is this T-IV stuff. I don't know why I just assumed it was Dexron derivative but I did.
Now the Mobil 1 label says it is "suitable" for use in applications where T-IV is specified: http://www.mobiloil.com/USA-English/...hetic_ATF.aspx
I've seen some other "sky is falling" proclamations on the internet for those who have done what I just did. My question is, is it ok in there or should I have the miserable thing flushed with T-IV? Already dumped $35 of fluid into it.
Paul
Old 03-22-2009, 09:43 PM
Three Wheel Ben's Avatar
The mobil is probably ok to use, still recommend t4, but t4 doesn't mix well with any other trans fluid. t4 is a semi-synthetic. I have always preached that the trans is engineered around the fluid it originally came with, ie the clutch discs inside.
I would probably have it flushed. Spendy but cheaper than a trans.
hth, ben
KC0ZBI
Old 03-22-2009, 10:04 PM
Is Mobil willing to back that with a warranty that says you get a new tranny if yours fails? If not, then I would suggest that a statement of suitability is worth what the Internets page it's written on cost to view.
Hmmm, $35 or $3500? I wonder if Toyota just renamed Dexron IV to T-IV or is it different? I dunno, I honestly don't. Not knowing, I would stick with the Mothership until I could figure it out. I know as well as anyone that all these codes, specs and what-not are as often written at the direction of a marketing department to guarantee demand for your stuff, but they are also a guideline from engineering. So I guess you have to figure that to your satisfaction. I personally don't have a problem using non-SAE graded engine oils that fail to meet zinc content guidelines. I think old junk like ours actually is being done a disservice by using the very modern oils that have too little wear protection for engines designed to use oil technology from 20, 30 and 40 years ago.
Old 03-23-2009, 09:54 AM
powderpig's Avatar
Mobil one meets the JWS 3309 requirements(Toyota T-IV) So you should be fine. Mobile one does not meet the Toyota World fluid they now require in some of the newer vehicles. I got most of this from Bob is the oil guy. Bill Van Beek may be able to give a better Toyota stand point. But it looks like if they meet the requirements, warranty still is in place if you still have one. It seem like from what I have read, people experence better cold shift patterns and a smoother tranny experence.
I googled Toyota T-IV fluid and got my info. I think you should be fine.
Old 03-23-2009, 09:34 PM
I did ask Mobil why just a couple months ago the silver bottles of Syn ATF didn't claim support and now the black bottles do. Here is the response:
Paul,
The Mobil1 AT was just reformulated a couple of months ago, if the
bottle does not state that it meets Toyota Type T-4, take it as it does
not meet this requirement you may have the older product.
Thank you for choosing ExxonMobil products.
If you need further assistance, please contact ExxonMobil at 1-800-ASK-MOBIL
MJ
