Old 04-11-2009, 09:44 PM
Nay's Avatar
Nay Nay is offline
Default 37" Trxus Are On
Had a set of 37" Trxus MT's mounted up today. Interco puts a big sticker on the tire stating to inflate to 65 PSI for balancing, they are taking the usual lots of weight but are running as smooth as the old 35" Trxus did @ 75 mph and spinning very nicely with my 5.29's.
Here's a couple of teaser pics
Old 04-11-2009, 10:48 PM
looks good... Are they going to rub?
Old 04-11-2009, 10:51 PM
I'm going back to Trxus too! That looks awesome Nay!!!!!! Not much room in the fenderwell though with true 37's!
Old 04-11-2009, 11:51 PM
Nay's Avatar
Nay Nay is offline
With no wheel spacers the rear tires will rub the frame at full stuff for certain. The tires to fender are 5.5" straight compression and axle to bumpstop is 5" (2" bumpstop drops), so that should be good. Full stuff under articulation is going to be tight, but given I had over an inch in all directions with 35's they should fit except for the frame rubbing.
Of course, I won't know until I get them fully stuffed. My rear LCA's are 3/8" lengthened over stock to correct pinion angle, and that seems to keep the tire perfectly centered with the bumpstop drop, but we'll see. I'll post some fully stuffed pics once I can get it flexed up.
Old 04-11-2009, 11:54 PM
Nay's Avatar
Nay Nay is offline
Go 37's
They fill up the wells big time. I am probably pretty close the min lift without more fender trimming to run 37's with a hub to fender measurement of 24" (no flares, obviously).
I'm curious to see if this will work without any additional bumpstop drop.
Old 04-12-2009, 12:14 AM
jacdaw's Avatar
jacdaw jacdaw is offline
Not only do these tires look great, that is a truly awesome color on an 80. I've never seen pix of your truck before. Love it!
Jon Newquist
TLCA 19964
Old 04-12-2009, 12:47 AM
Those are some BIG tires Dave
Looks great!
Old 04-12-2009, 01:12 AM
Nay's Avatar
Nay Nay is offline
Thank you, that's my Durabak project from last Fall. If you searched "Holy Guacamole" you'd probably find the thread
Old 04-12-2009, 01:13 AM
Nay's Avatar
Nay Nay is offline
Looks great!
There are huge
I'll shoot you a PM on getting together on the Toyos tomorrow.
Old 04-12-2009, 01:21 AM
Originally Posted by Nay View Post
Go 37's
I need no more lift or tire hight for what I need my 80 to do! Rubicon tested and approved!
