Old 04-14-2009, 09:04 AM
Bikeman Bikeman is offline
Default Need to Borrow "Fish Scale" For Bearing Preload
Title says it all. I need to borrow one to set the preload of the rear bearings. I have the spanner tool, just need a "fish scale". I can't do the "feel method". Southsiders? Thanks.
Mike
2001 Honda XR400 with goodies
Old 04-14-2009, 09:42 AM
Romer Romer is offline
Mike,
You can boorw mine. They are only a few dollars at Harbor Freight
I am near Arapahoe RD and Jordan RD. Should be home after 5
Old 04-14-2009, 09:49 AM
jacdaw's Avatar
jacdaw jacdaw is offline
I'm on the north side but I have one you can use and I'm around all day. Scales on it are 0-50N and 0-5000g. It's medical grade for I.V. pole use. Pac-Sci brand.
Jon Newquist
TLCA 19964
Old 04-14-2009, 09:50 AM
I have one that you could borrow as well. It may take me a few minutes to find it in the garage as I don't recall seeing it in my tool box during the WBPP. I'm near C-470 and University. I picked mine up at the Discount Fishing and Tackle on Santa Fe just north of Dartmouth - was about $6 IIRC.
Old 04-14-2009, 09:55 AM
FWIW, Marlin sells a nice one. Might be worth throwing one into the cart the next time you order something. I have one similar to this one, you are welcome to it Mike. Arapahoe and Peoria during the week.
http://marlincrawler.com/hardware-to...kle-pull-scale
Old 04-14-2009, 10:00 AM
jacdaw's Avatar
Based on Marlin's specs mine might not be helpful at all. 5000g is only about 11 lbs.
Jon Newquist
TLCA 19964
Old 04-14-2009, 10:49 AM
Might be a little low. You don't need 50 lbs, up to around 25~30 lbs is enough. But these things are usually available roughly by orders or range, i.e 0-5, 0-50, 0-150, etc. It's like torque wrenches. You need say 15 ft-lb and you can choose a tool that goes from 25 in-lb to 250 in-lb or 10 to 150 ft-lb, so you are either at the very top of one or the bottom of another.
Old 04-14-2009, 11:21 AM
Mike,
I have one as well if none of the other prospects work out. It is digital if that makes a difference. I was taught the "feel" method by Three Wheel Ben and it does work - Although I still don't trust myself so I check it with the scale and everytime I am usually close to spot on
Old 04-14-2009, 11:47 AM
Thanks guys for all the offers.
Jeff, you are the closest and the digital sounds nice. Can I get it from you sometime Wednesday. I am off tha day/night. Thanks.
Mike
Old 04-14-2009, 04:36 PM
No problem Mike. Don't let the digital fool you though...Picked it up at Harbor Freight if I remember right. I should be home after 6pm or so or I can leave it in the milk box for you
I should have mentioned that I'll need it back sort of quick as I plan to get my front axle rebuild done here in the next week or so before CM. Shoot me a PM and we can figure out what works for you.
