Old 04-18-2009, 09:22 PM
bigbluefj's Avatar
Honorary Canuck Member
Watch the drag please explain??
bigbluefj
Old 04-18-2009, 11:26 PM
Originally Posted by Mendocino View Post
Watch the drag...
KĜUBN
Old 04-18-2009, 11:28 PM
bigbluefj's Avatar
bigbluefj
Old 04-19-2009, 09:34 AM
Mendocino's Avatar
LOL! UB
Jeff
Old 04-19-2009, 10:22 AM
Mendocino's Avatar
If the rod between the pedal and the ms is too long it actuates the ms piston and creates brake drag. I added an 80 ms to my 40 and had this problem. A proportioning valve will not fix this; it changes the amount of braking force from front to rear. There is a lot of confusion about this and a lot written on Mud (check the signal to noise ratio).
I put my 40 on jack stands to make sure everything actually turned properly with no drag.
Jeff
Old 04-19-2009, 10:43 AM
Actually, it's the rod between the MC and the booster that is not adjustable and has to be a specific length, the rod from the booster to the peddle is adjustable.
KĜUBN
Old 04-19-2009, 11:00 AM
Mendocino's Avatar
Thanks, that's what I meant.
Jeff
