Old 04-19-2009, 04:54 PM
Default Wayward Castle Nut
Now that power is back on, CM prep has back on track. I was crawling around under my 71 40, doing visual inspections, lubing u-joints, adjusting parking brake, checking fasteners, when I looked over next to me on the garage floor and there was a castle nut!
Yikes! Where did it come from?
It's a M12x1.25 (fits 17mm wrench), and fits shock mounts and tie rod ends. I checked all shock mounts and tie rod ends. Checked engine mounts too, although they are larger. Where else should I check?
Due to the power being out over the last couple days, I have been bumping into things in the dark in the garage, and it is possible I knocked it onto the floor by accident. It was roughly under the oil pan. Last time I swept the garage was a few days ago, before the storm.
Where else should I look?
Thanks and happy cruisin'!
Old 04-19-2009, 05:09 PM
Yeah, I think you're got them covered. TRE, ball joints, Pitman arms, relay rods, shocks, steering stabilizers.
I once had a bolt fall out on the floor randomly, but I recognized it as one that I'd dropped, lost and just replaced from the stash. I think it was a bolt on one of the motor mounts AFAIK. Anyway, I think it fell into a frame hole or something and finally vibrated out. I've had sockets do the same thing, finding a rusty 14mm one day. LOL!
Old 04-19-2009, 07:26 PM
Thanks Dave, yeah I checked the steering stabilizer too. They're all there. [scratches head]. Hopefully it was a table (near the rig) I bumped in to in the dark. I toss misc. fasteners on that table on occasion, and that may have been the source.
On the good side, I adjusted valves today, and only 3 out of 12 were slightly out since I assembled this engine ~18k ago, with mismatched lifters and a different cam. I am beginning to wonder what is all the fuss about keeping lifters, rods and cam lobes matched up.
Old 04-19-2009, 09:11 PM
timmbuck2's Avatar
did you check the bolt behind your left ear? mine is always loose....
* 00 LC
* 99 Saab Convertible
* 76 Piggie
* 1996 T-100 with 396k miles
has a 2008 FJC
KDěTIM
Old 04-19-2009, 10:45 PM
If you would put the cotter pin in like you are supposed to your head would stay tighter!
KěUBN
Old 04-20-2009, 08:59 AM
I went to college with a guy named Tim Cotter...weird.
Old 04-20-2009, 09:09 AM
timmbuck2's Avatar
good idea...I tried loctite blue but it made me dizzy.....
* 00 LC
* 76 Piggie
has a 2008 FJC
KDěTIM
