Old 04-20-2009, 10:19 PM
Default Suggestions for Unsticking Hood Release!
My hood is stuck closed. Tried WD40, Lubricants, the hood release won't unlatch the hood???? Any suggestions? 88 Toy Pickup?
C.J. Bowen
2015 Jeep Rubicon Hard Rock, 2000 Jeep Grand Cherokee
Old 04-20-2009, 10:21 PM
Did the cable break or come undone on the latch? I've screwed up getting the cable housing snapped back in the bracket under the dash after removing the lower plastic section, which kept the hood from popping open.
Old 04-20-2009, 10:37 PM
Haven't broke the cable......put my weight into the hood and that didn't work......
C.J. Bowen
Old 04-21-2009, 12:05 AM
Disappointing
Have someone hold the release all the way open in the cab while you futz with it in front of the vehicle.
Originally Posted by nakman
Old 04-21-2009, 08:09 AM
Have tried that while standing on the front bumper using my foot, leaning against the hood, shoving against it. I think a coat hanger will be my next try. See if I can hook it to the latch and pull it..........
C.J. Bowen
Old 04-21-2009, 04:17 PM
theboomboom's Avatar
whatever you do, don't go the brute force route, DAMHIK...
i'm not at all familiar with the setup on a mini, but if you may need to consider unbolting and removing the locking mechanism itself to resolve the issue.
Rick Maestas
KD0CGE
1997 T100 4x4
Old 04-22-2009, 09:11 AM
To follow up!
After using a hammer and a metal tap rod, and just doing some light tapping on the hood latch housing. It dislodged a small bolt that fallen in between the release mechanism. So, a foreign bolt was causing the problem that was lodged in there, but no more...Everything works fine, and your right! Don't try forcing the cable to open the hood.......
C.J. Bowen
